  #1
Old February 27th, 2009, 03:58 PM
wjorge3974 wjorge3974 is offline
Default need a can not find part for a mercury 150
I have a 1985 Mercury xsr2 Black Max 150 and the shop said that the Advance module is bad and they do not make the part any more the part# is 93772A1, Does any one know that i can get. thank you
Last edited by JB : February 27th, 2009 at 06:25 PM. Reason: solicitation deleted.
  #2
Old February 27th, 2009, 06:26 PM
JB's Avatar
JB JB is offline
Default Re: need a can not find part for a mercury 150
Try www.tcoutboard.com, Wjorge.
Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old February 27th, 2009, 06:59 PM
rodbolt rodbolt is offline
on that engine we normally eliminated the advance module anyway.
with some of the fuel grades we get and the lack of a knock detect sensor on the 150 it sometimes gave piston issues above 5000 RPM.
there is a bulliten on it someplace.
  #4
Old February 27th, 2009, 09:12 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Like Rodbolt said just do away with it. Unless engine is on a very light boat you will not even notice its gone.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
  #5
Old February 28th, 2009, 05:06 PM
Quote:
I have a 1986 dyna-trak 180ss 17' would you consider that a lite boat? or a heavy one? I figer a heavy one..
  #6
Old March 1st, 2009, 06:25 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Those modules were responsible for many an engine failure. They would advance the timing and not retard it again and the pistons would get all hot and bothered. Remove it, bin it, go boating.....
Have fun,
Chris.......
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #7
Old March 1st, 2009, 08:49 AM
this stabilizer/advance module served 2 functions, one was to alter the switchbox bias to advance timing if the RPM fell below about 600 RPM to stabilize the idle speed, the other was above about 5000 RPM it would add about 6* more ign timing, by altering the switchbox bias again, if all engine functions were perfect and the hull propped correctly and the correct octane fuel was used it worked very well.
it did not like 6 month old fuel, did not like a weakening fuel pump, any fuel restrictions, any varnish buildup in the main jet circuits or about anything else.
had they used a knock detect circuit like the EFI 200 it may have worked better.
but try to look up the bullitens on the spark advance or idle stabilizer module.
I normally dont reccomend trying to re-engineer products.
but do discuss this with your repair facility and do try to find the tech bullitens concerning the module.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need to find S/N for old Mercury 150 HP Fyrtrkman Mercury & Mariner Outboards 4 April 25th, 2009 01:33 AM
need help to find part lowrider27020 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 December 26th, 2008 01:22 AM
Need to find name of part cah412 Johnson & Evinrude Outboards 8 March 27th, 2008 10:50 PM
need to find a replacement part-anchor rope well cover memaburkejudy Pro-Line Boats 0 July 20th, 2006 09:59 PM
Where to find part # for force 150 stator Quick Cal Force & Chrysler Outboards 3 June 6th, 2005 11:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
