Re: 18 evinrude tank and hose
You may have to add a fuel pump if you want to use a modern, single fuel line, fuel system.
If you have no fuel pump you will have a triangular shaped connector on the engine for the double line system. One line carries pressure to the tank to pressurize it and the other carries fuel to the carburetor.
Double lines and tanks with the correct fitting can usually be found on eBay.
I recommend adding a fuel pump and using modern single lines and tanks. I think there is an article on how to do it in the Engine FAQs Forum.
Good luck.
