I have a 2006 Johnson 9.9 HP that came with a rowboat I just purchased. When I would use it and when it would warm up, it would stall at low idol. It also would seem to run a little rough. Full speed I had some vibration.
I took it and had it serviced. They fixed the stalling problem but it then wouldn't start when cold. So they worked the motor alittle more and found an adjustment in between. When the Engine is very cold it's still hard to start. It's also running alittle rough. One last thing is when I remove the lower unit from the water bucket it has exhaust (some type black) all stuck to the bottom.
Do you have any ideas as to what this problem could be. About the motor running a little rough, the marina said that's normal for this Johnson motor. Or is it? The motor could of sat a year or 2 before I purchased it. Also the plugs were gaped and replaced.
Any help would be very grateful!
