  #1
Old February 26th, 2009, 08:05 PM
johnkbl johnkbl is offline
Default How to test a Mercury Force 120 without starter
Hello!
I found a Mercury Force 120 1999 outboard, and it has a burned starter. (That was what the owner said). The owner also said that the engine has only 90 hours of use and has never been used in saltwater. If the starter is the only problem the engine has, it will be a good deal for me. I am ignorant in how to test the general state of the engine. Ofcourse a visual inspection will give me a lot of information. I dont want to buy the motor, replace the starter, and then, find that something else is wrong.
Could anyone here tell me how to check if the engine is OK without buying a new starter just to check it?
Thanks!!!
  #2
Old February 26th, 2009, 08:07 PM
Default Re: How to test a Mercury Force 120 without starter
I forgot to say that the engine is located about 150 miles from my home.... So, I dont have a lot of time and resources there.
Sometimes I think that I like deals with problems... but.... damn! it is fun!!
Thanks guys!!
  #3
Old February 26th, 2009, 09:38 PM
jimg984 jimg984 is offline
if the starter is burnt out after 90 hrs... he must have used the starter has a trolling motor... beware!! cant tell much about a motor without a starter to crank it over (i'm sure know that)
  #4
Old February 26th, 2009, 10:31 PM
JB's Avatar
JB JB is offline
Betcha the starter is okay and he has bad wiring/connections to it.
Definitely worth looking at, but unless you can turn it over there isn't much you can do to test it.
It is not a Mercury. It is a Force. It cannot be demonstrated, even on muffs.
That means don't spend much on it. I wouldn't offer over a couple hundred for it as is.
__________________
RED SKY at night. . .
JB
  #5
Old February 26th, 2009, 11:00 PM
lowkee's Avatar
lowkee lowkee is offline
Starters don't cost THAT much. I'm always leary of a guy who doesn't replace a part that will drastically affect the price of what he is selling. I see it as a way to say "runs perfect, but oops, I forgot the keys.. you'll just have to trust me.."
__________________
1990 Bayliner Capri 2050 BR - (My first runabout; Never seen her in water) ***Restore on hold until Jan 2010***
Restoration status: 0% --1--2--3--4@--5--6--7--8--9--10 100% Watch my progress here
1-Teardown 2-Transom 3-Stringers 4-Deck 5-Paint 6-Repower 7-Interior Frames 8-Seating 9-Water Trial 10-Upholstery
The 10 steps of restoration denial - Which step are you?
  #6
Old February 26th, 2009, 11:06 PM
cdnfthree2's Avatar
cdnfthree2 cdnfthree2 is offline
And since boat motors aren't operated in a dirty dusty environment, the best cleanest motors visually could actually be the worst pieces of junk around. Visual inspections don't always tell as much as youd like with an outboard.
  #7
Old February 26th, 2009, 11:37 PM
Frank Acampora's Avatar
Frank Acampora Frank Acampora is offline
Remove the plugs and turn the flywheel by hand. If it turns easy, the engine is not locked up or grinding anything. Next, put you thumb over each plug hole while turning the flywheel. If it doesn't blow your thumb off, then there is no compression and the engine needs an overhaul.
If it does blow your thumb off, At least you know it has SOME compression. Thus, it may be acceptable mechanically. If it goes into and out of gear, and the prop turns, at least you know the lower unit is free. BUT remember that even well worn dog clutches will lock up and you will not be able to make them pop out of gear by hand.
Since you can not crank the engine, you can not assess the spark on each cylinder. While ignition parts are fairly expensive, they are easy to install and thus become a bargaining chip in price.
HOWEVER: If the engine can not be cranked and started, then you must buy it as a parts engine--depending upon condition maybe up to 300 bucks or so. And in making your decision, don't forget to factor in what gas is going to cost to look at it and bring it home.
BUT LIKE YOU SAID: It can be fun.
  #8
Old February 27th, 2009, 12:18 AM
hey Frank!!!!!! great explanation!!!!!
i will check this engine maybe this weekend. i will try to get a leakdown tester and test the engine with a compressor..... but... that would be the first leak down test i have ever made.
also, i think that I can try to crank the engine connecting in some way a drill to the flywheel or to the propeller shaft. Yes, it is a crazy idea, but maybe it will work. If I survive to that experiment, will tell you about it.
the engine price is about 600, the starter here costs about 200. (i dont live in usa, have to pay shipping and a lot of taxes).
Thanks again.... more answers are always welcome!!!
  #9
Old February 27th, 2009, 01:45 AM
Bigprairie1's Avatar
Bigprairie1 Bigprairie1 is offline
I'm not too sure about this (Frank or RR might know) but that flywheel might have a pull start capability on the flywheel. Not that I would ever want to actually try to start it that way). Anyhow, if it does, take a friend with you and see if you can get some heavy cord and a handle and try to give it a compression test via a pullstart. Again, I'm just spitballing here but it may be possible in lieu of there not being an operative starter on it.
BP
__________________
Big Prairie
90' Capri- 90 Force
If it was easy, everyone would be doing it.
  #10
Old February 27th, 2009, 04:30 PM
bman1bpm's Avatar
bman1bpm bman1bpm is offline
You could hook some jumper cables up to your car battery can hook the negative up to the outboard block and tap the positive to the starter's positive lead. This would at least check to see if the starter works.
I'd think that its wiring too, either that or it has a lot more than 90 hours on it.
Either way, I wouldn't pay $600 for a motor that isn't running
  #11
Old February 27th, 2009, 09:49 PM
You can wrap a rope around the flywheel, but if the engine is not on the boat, you will move it rather than actually try to start it. Even if it is on the boat, while a good running engine can be pull started, one that has not run in some time will most likely just pull your arm out and tire you without starting.
Where is not in the USA? Canada?
Like Robin Williams said in his stand-up routine, "Canada is like the loft over a really great party."
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How to test a starter and selonoid jb_1961 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 September 3rd, 2008 12:20 AM
how do i find year of a mercury force 120 mikeq Mercury & Mariner Outboards 1 April 9th, 2008 03:48 PM
how do I test a starter solenoid? jwilkey84 Johnson & Evinrude Outboards 12 February 5th, 2008 11:19 PM
COMPRESSION TEST FORCE 120 JET avl10043 Mercury & Mariner Outboards 2 February 2nd, 2006 02:40 PM
If I trial test a Force 120, what should I look for? flaboy Force & Chrysler Outboards 0 May 3rd, 2002 06:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
