Re: how do I test for spark?
You can buy a cheap inline spark tester or timing light at any automotove store. Then just insert it between the plug and plug wire and PULL. Repeat for each cyl. You'll visually see the spark if it's there. ( Also a good tool to see if you have spark break-up at different RPM's.)
