Trying to sync ignition/carb on above. OEM manual has picture of how the 2 marks on throttle cam should line up with projection on intake manifold. With remote throttle pulled all the way back (butterfly closed) the marks on the cam still need to turn 1 and 1/2 inches clockwise to line up with the projection. I can't move the armature plate by hand at all. I have never attempted a sync before and don't want to break anything. Should I be able to rotate the armature plate? If so, how?
By the way, the motor starts and idles fine, even in gear but with any acceleration at all it dies. I am thinking the sync, or lack thereof is part of the problem.
Thanks.
Thanks.
