Re: Is this too much Prop for this Boat?
If you make a prop decision based on a poor running engine you will have the wrong prop when the engine problem is corrected. You must get the engine running right, go through the set up tests of adjusting the engine up and down to get best performance, and making sure the hull is clean and loaded as you will eventuly use the boat. Then run the wide open throttle test to get rpm and speed numbers for a worth while prop recommendation. If other stuff is not right you will buy a prop and it will be a wasted investment.
