Re: ~~ Compass Question ~~
Better compasses are bigger, with finer markings on the card and usually greater damping, and cost more (sometimes a lot more). As said above, a compass is a compass and will work the same on any boat/ship.
Most people with 16' boats don't want a 8" diameter compass and most folks with 50' Hatteras don't want a dinky little compass. That is the only reason I can see for designating a compass as suited to a particular size boat.
It may have to do with the quickness of a smaller boat as it yaws, pitches and turns, versus the same yaw pitch and turn but a lot slower and at smaller angles on a big vessel.
An abnormally big compass on a little boat will almost certainly receive damage under the bell (card) in the balance cone "if" the action overreaches the dampening speed and limits of travel, where a smaller compass won't. It has to do with "moment arms and angles" (Viscosity of fluid too.)
In the aicraft business we sometimes used different liquids according to preference (It's their Dollar!) for more or less damping quality (This of course being on small 1 to 6 seat A/C's and the older style of compass equipment.
For the small dash units on the aircraft we serviced, we used "jet A" kerosene for a secondary filler (a bit faster response) as there were no guidelines on the refills (alcohol was used too but not in aircraft, as it has a lower flashpoint than the the kerosene and could cause explosions), and the kero wouldn't freeze or contract past the bladder (expansion buffer) capacity, at 40 or 50 below zero.
PH.
