I decided to make a separate thread for this one as the other is more mechanical. I was reading through my Gale factory service manual and they outline a procedure for removing dents in fuel tanks. They basically say to attach an air line to the outlet of the tank and use a compressor to apply 8-10 lbs of air in the tank. Then with a torch, heat up around the perimeter of the dent and work inwards facing towards the outside. Once the area is heated they say to gently tap around the edges with a wood mallet which helps pop the dent out with the internal air pressure.
Anyway, has anyone used this method and what do you think, I have a good sized dent in the front of my tank and another, smaller towards the rear which I would like to try and remove so I can repaint the whole think and make it look nice.
