I removed the lower unit to change the water pump impeller, but in doing so I pulled the shifter rod loose inside the lower unit. I cannot tell from the repair manual how this rod connects inside the lower unit and do not know if I now have to disassemble the entire lower unit (remove bearings, etc) or is there an easier way?
