pataterchip
- Dec 1, 2008
- 19
2001 60HP Bigfoot S/N#OT 294069P
I took it in to have the carburetors synced which was done. The shop doing the work has informed me that while the motor is idling and or revving the top two cylinders go off line or Miss from time to time but do come back. There is what he felt confident was engine oil coming out the thru prop exhaust but no water in the oil crank case and not enough oil to drain the oil level any detectable amount. He does not feel it is either carburetion or ignition related I am supposing because he told me he had diagnostic tools hooked to it and did not see a problem. The carbs were rebuilt because the motor would miss and try to stall at around 2500-3000 RPM but only under load at the lake not hooked to the hose. Any ideas?
