Re: full synthetic at what mix ratio?
Thanks for the input guys. Too good to be true? I spoke with the tech department (yes they have one 715-392-7101) and was told they have field tested this product at 400:1 without detonation. AND they have never fielded a warrenty call for a 2-stroke with this product. Plus they confirmed 100:1 mix for my motor. I am going to run it at 80:1 and keep you posted.
I included their press release below. (JB, I never saw a forum member with 30+ thousand posts. now thats conviction)
AMSOIL SABER Outboard, from AMSOIL INC. of Superior, WI, is a special blend of multiple synthetic base oils and select additives designed for lean mix ratios in outboard motors. Clean burning SABER Outboard prevents plug fouling, improves throttle response and reduces smoke and lowers emissions. The specially formulated two-stroke oil prevents corrosion and reduces friction and wear. It is recommended for applications specifying TC-W3 or API TC.
Recommended for use as a 100:1 pre-mix, SABER Outboard is compatible with most mineral and synthetic two-cycle oils and offers the following benefits:
* Prevents plug fouling and exhaust port deposits.
* Extremely versatile; may be used in range of applications, not just outboards.
* Cost effective compared to oils mixed at 50:1.
* Produces low smoke/ low odor and reduced emissions.
* Exhibits low aquatic toxicity, better for lakes, rivers and streams.
Instructions: SABER Outboard should be mixed with gasoline at 100:1 for normal service in all types of outboard motors, personal watercraft and jet boats, as well as snowmobiles and ATVs. For "Severe Duty" applications such as racing and continuously operated industrial or commercial motors, richer mix ratios of 50:1 to 80:1 are recommended.
