usernamekane
- Dec 13, 2008
- 11
Hi all, what would cause my 35703C to push, as if it had the muscles to do so, its own throttle down to nothing, while sputtering out? This only happens when I try to bring it back from a high throttle start. It will run all day in neutral at any speed above 1/4 throttle or so. It will also run in forward gear this way, though I'm not sure for how long, I didn't want to leave the bay with a questionable motor. Below that, it drops its' own rpms to an eventual zero. It's pushing against my hand on the throttle, at the control box or back at the motor with the cables disconnected. New teleflex's by the way.
I bought this motor from a mechanic, and it worked fine, for about 2 running hours.
Then it ran rough, inconsistently, and would dog down at high speed.
Then I let it sit for a long time. Too long.
Then I took it to a mechanic, I was afraid I would mess up the adjustments and the small unknown intricacies of the carb, although I "knew" the carb just needed a rebuild and I would be off. He also replaced a bad ignition coil. And the fuel pump.
Then, I took it out and it was perfect, except: under power, it would get up on plane, then 2 seconds later going up and down in throttle in its full range, think of it as the motor as screaming: Wow! Wow! Wow! over and over.
Then I replaced the other ignition coil.
Then I replaced the vacuum hoses and major electrical lines.
After no progress, we took it to another mechanic. They replaced the two coils under the flywheel, the sensor coil and...bah, can't think of it now...the bigger one. They also replaced the upper crank seal, as it was bad, and thats what burned out the coils, yada yada.
Now, this is where I'm at. All I can think of is the stator, now. Or the power pack. But, that doesn't make sense. Could it be an internal, more major problem? Compression is good, spark plugs are new and gap is good. Idle needle in front of carb is well adjusted. Fuel externals(bulb, tank itself, etc.) are also good. Thanks for the help, guys.
