I have a 1971 55HP outboard Chrysler, Model 557HC Serial 3188. I found mostly water in the LU. I just received my LU reseal kit and am going to do it this weekend. I also receivied the Impeller. Question is: When I remove the LU (mine has a extendion on it) Do I need to remove from the below Motor leg down or from below the extension down? Is this going to be as hard as it looks? I do have all the Chrysler manuals for this particular outboard motor. (service, parts, and electrical manuals) Any suggestions?
Also will I need any special tool to remove parts behind Popeller to change seals? Will regular tools do to do this job?
Thanks
Thanks
