  #1
Old February 20th, 2009, 05:29 PM
bassman 46 bassman 46 is offline
Default loss of power in 96 150 Mercury
I was traveling down the lake at about 3/4 speed when all of a sudden the moter started to loss power. The power loss was like you just shut off part of the moter.
The boat will slowly get back on plane but the moter has only a little power. The moter will idle and rev up out of gear. I have checked the plugs and I have spark to the pulgs.
I also noticed that the tack stopped working. I dont know if that is related or not.
All help Needed. Dont have a lot money to throw into the moter trying to find the problem.
96 Mer 150.
Thanks!
  #2
Old February 20th, 2009, 08:47 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Default Re: loss of power in 96 150 Mercury
Borrow a compression guage and a spark tester. Remove spark plugs and check compression. It should be 100psi or higher and cylinders should be within 10 psi of each other. If ok ,install spark tester and check spark on every cylinder. Post back the results and we will walk you thru additional testing. From what you have posted you may have had a stator take a dump. Please post if carb or efi and serial # so we can get you the correct part numbers.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loss of power on 96 evinrude 48 Fireson Johnson & Evinrude Outboards 8 April 9th, 2008 03:53 PM
Mercury 150 Â’89 loss of power until warm reyb Mercury & Mariner Outboards 1 October 5th, 2005 07:29 AM
150 johnson power loss kmdneptune Johnson & Evinrude Outboards 1 August 10th, 2005 06:44 AM
'96 Johnson 200HP - loss of power under load tak Non-Repair Outboard Discussions 2 July 30th, 2003 12:12 PM
96 Evinrude O-pro 150 loss of 3cyl power when hot GARYPLA Johnson & Evinrude Outboards 1 July 29th, 2003 06:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
