removal of lower unit on 850 merc
QSS
hi guys i have a 1977 850hp mercury that i,m about to remove the lower unit to replace the water pump but to disconnect the shift rod is the roll pin in the shift connector link under the bottom carb the only way to remove or ?
thanks
jimg984
Re: removal of lower unit on 850 merc
it has spline coulper on the shift shaft inside the lower unit,, which should slide apart as the lower down the lower unit,,, you need a manuel to give you step by step instructions,,, cheaper than messing it up and getting someone else to fix
mnydvr
Now THATS a WHOLE lotta motor! please,tell me its on somthing small and FAST!!!:D
Laddies
Banned
Here's removal and installation of a unit.
QSS
Its an 85hp merc they called it an 850 as what is on the decal on side of engine cowl
mnydvr
so put it on a 12ft alum. boat and I'll be happy!!!:p
