lakeduckhunter
- Oct 31, 2008
- 9
Hello everyone. I have a 1992 Evinrude 15 hp motor that I recently purchased and decided to change the impeller. I have took apart the lower unit and everything went fine, however when I inspected the lower unit there was a lot of dirt or gime in it. It wasn't around the waterpump housing but by the shift rod. Is there any way to clean all of this out without taking it apart any further. Also the reason I am changing the impeller is because I thought it had quit working but it looked really good except for the grommet on top of the housing, the rubber had broken off, would that cause it not to work properly. Thanks.
