  #1
Old February 18th, 2009, 09:58 PM
bob proudfoot bob proudfoot is offline
Default mercury 45 hp loss of power
To anyone ,We have a 45 mercury that we have loss of power in the water at full throttle.It did run at full throttle for about 20 min and then shut back down to half speed . all plugs are firing ,switched the stater wires and no change.We haven't checked the oms on the trigger yet but thats the next step.It could be the switch box but not sure.We were thinking it could be the fuel lines but the motor starts and runs good at idle and at half speed.are there any suggestions out there to help us.We would appreciate any suggestion. Thanks
  #2
Old February 19th, 2009, 05:12 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: mercury 45 hp loss of power
serial #, did it run hot? have you checked compression, vent on fuel tank open????????
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old February 19th, 2009, 09:30 AM
Quote:
It ran cool, compression 100 or better on each cylinder,vent open.
  #4
Old February 19th, 2009, 10:00 AM
Laddies Laddies is offline
Did you try pumping the primer bulb to see if the fuel pump was OK? I would need test the trigger but I think you will find it OK inless it has a damaged wire. Chances are it's a bad box which can not be tested except with a DVA to test input and output.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #5
Old February 19th, 2009, 07:58 PM
yes we pumped the gas up while we were running and it didn't make any difference. We are going to check the fuel lines and then the oms on the trigger and go from there.There could be a small line at the motor not letting the gas to get to the engine. I hope its not the switch box but possible.It would be our luck and it would cost more. Thanks for the suggestion.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
9.8 hp Mercury 110,loss of power cfaulkner Mercury & Mariner Outboards 3 June 30th, 2009 04:41 PM
1985 Mercury 115 hp power loss 85Lund Mercury & Mariner Outboards 27 May 10th, 2009 12:28 AM
2001 4 stroke 50 hp mercury power loss!! swantek1 Mercury & Mariner Outboards 4 March 19th, 2009 09:11 PM
Mercury 65 hp has power loss yorel Mercury & Mariner Outboards 4 June 5th, 2003 08:02 PM
loss of power 1981 75 hp mercury ob mercrude Mercury & Mariner Outboards 3 December 28th, 2002 03:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
