I have a Chrysler 55HP outboard. Model 557HC Serial 3188. I am changing the impeller and I noticed caked up oil just under the rear of the lower unit gasket, In front of propeller. I am pretty sure it is the lower unit gasket. First question. Do I need to change the gasket under the impeller plate when I change the impeller? Also, do I need to change any other gaskets, like where the leak is. I have the lower unit gaket but was wondering if it could be a seal under the propeller. I am thinking if that seal was bad it would not show all around the outer part under the lower unit gasket. It would show inside, under propeller.
