  #1
Old February 17th, 2009, 08:27 PM
lekslk lekslk is offline
Default 85 evinrude 140 crankshaft seal replace
HI There,
Can te lower cranshaft seal be changed without splitting crankcase?
Thanks,
Lance
  #2
Old February 17th, 2009, 09:55 PM
reeldutch's Avatar
reeldutch reeldutch is offline
Default Re: 85 evinrude 140 crankshaft seal replace
nope
  #3
Old February 17th, 2009, 11:58 PM
Is that due to the bearing?
  #4
Old February 18th, 2009, 04:34 AM
F_R F_R is offline
Well, I haven't done a 1985, but have had plenty of earlier models apart that were of similar construction and I say the seals can be replaced without splitting the crankcase.
Remove all the screws from the crankcase bearing head, including the small ones near the center, and then the head will pull out of the crankcase. It is a slip fit with o-rings. Then the seals are replaced in the head as usual.
The ball bearing is snap-ringed to the crankshaft and will stay there as you pull the head off of it. It is a snug but not press fit. In fact the same thing applies even if you had the case split.
Hint: to reinstall, insert a couple of long screws (with their heads cut off) into the bearing retainer plate to act as guide pins when you reinstall the head. Otherwise, you can't find the holes with the head in the way.
And use some sealer under the heads of the small screws.
Just my 2c.
  #5
Old February 18th, 2009, 08:59 AM
Thanks for he reply, I will give it a shot. I really did not want to split the case just to cange a seal.
Thanks,
Lance
  #6
Old February 18th, 2009, 07:32 PM
reeldutch's Avatar
how will you get the 4 retainer bolts back in the retainer plate?
  #7
Old February 18th, 2009, 08:11 PM
Well I did replace the seal & bearing while I was there without splitting the case. I put 2 long bolts into the bearing retainer put some o-ring lubricant on & tapped it back in with the handle of a hammer. Then I put in 2 bearing retainer bolts in, removed the 2 long bolts I used to line it up, & installed the other 2 bolts. Good thing I did pull it out cause the bearing was pitted & race was actually cracked. thanks for your opinions.
  #8
Old February 18th, 2009, 08:12 PM
F_R F_R is offline
Quote:
As I said, use a couple of long bolts with the heads cut off as guide pins. Install the bearing head over the guide pins, which will align the holes. Then start two of the retainer bolts and then remove the guide pins and do the other two retainer bolts.
Same as doing a gearcase bearing carrier.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude lower crankshaft seal MikeOlson Johnson & Evinrude Outboards 0 July 18th, 2008 12:14 AM
1962 40hp evinrude upper crankshaft seal ? jmc03021013 Johnson & Evinrude Outboards 3 April 24th, 2005 11:45 AM
85 mercruiser 140 Crankshaft pulley removal doman Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 16th, 2004 10:30 PM
Evinrude 115 crankshaft seal Paul Witt Johnson & Evinrude Outboards 3 July 16th, 2003 04:32 AM
'60 Evinrude 18 crankshaft seal Fontanaman Johnson & Evinrude Outboards 4 September 4th, 2002 04:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
