  #1
Old February 17th, 2009, 01:13 PM
willdoss willdoss is offline
Default Prop Recommendartions for 24' Pontoon?
Hi,
I recently re-powered my 24 ft Grumman Pontoon boat with a 2008 90 HP Evinrude E-tec. The prop that the dealer put on is a 15 inch diameter 13.5 pitch stainless Solas three-blade prop. I anticipated that I would have to try out the prop and possibly swap to a different pitch so that's not a big deal for me.
Anyway at WOT, the Engine is only turning 4600 RPM, so the dealer suggested that we go with a 13 pitch three blade (the operating range for the Engine is 4500 - 5500 rpm.) I'm hoping to get 5200 - 5300 RPM at WOT.
My question is this, for pontoons, are 4 blade props a better choice? Can you justify the extra cost for a 4 blade in added fuel efficiency, stability, etc?
I know that this thing is never going to be a speed demon, it is, after all a pontoon, I just want the best prop for a pontoon application, with fuel efficiency being the most important factor.
By the way, even at only 4600 RPM the E-Tec 90 pushes this pontoon boat to 24 mph! At 3000 RPM it cruises at 12 MPH. The engine will push you back in your seat when it comes out of the hole too. Lots of power in a small 90 HP package!
  #2
Old February 17th, 2009, 01:48 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: Prop Recommendartions for 24' Pontoon?
There are props made specifically for pontoon boats. We're kind of assuming you mean the prop is 13 1/2" in diameter (not 15") and the pitch was 15, now looking at a 13. Most of the pontoon props for your motor will be in the 14" diameter range. The blade shape and rake angle are different too.
If your dealer is having trouble finding one, shoot me an IM or email. We can get you headed in the right direction to find one.
  #3
Old February 17th, 2009, 02:25 PM
steelespike steelespike is offline
Generally the prop that pushes the boat fastest will produce the best mileage.
Your 90 will use about 9 gph(gallons per hour)@ wot(wide open throttle)
The farther the boat goes in an hour the better the mileage.
The toon doesn't plane so best mileage usually is between 6 to 9 mph.
not the most practical speed so you need to select the speed that best suits your needs.
There are 4 blade props that are specifically for heavy hard to push applications.Sometimes a 4 blade is recommended for venting(cavitation) problems.Rule of thumb says a 13 would put you at about 5,000
If your not having any problems with venting you might consider raising the motor one or two holes.Won't gain you too much but the less dragging through the water the better.Careful adjustment of trim might help as well.
  #4
Old February 17th, 2009, 03:09 PM
Thanks for your comments, I really appreciate them.
As far as lowering/raising the mounting bracket, the engine does have power trim, but raising the engine any significant amount causes cavitation (again, a characteristic of pontoons) I can raise it a little, but not much.
  #5
Old February 17th, 2009, 03:12 PM
The prop has 13.5 x 15 engraved on the outside of the hub, I was assuming that 13.5 was the pitch, but, as you said, its the diameter.
So you are saying that most pontoons use 14" diameter props? Maybe I should try a 14 x 14.5 or maybe go to a 4 blade and try again?
THanks for the help!
  #6
Old February 17th, 2009, 04:11 PM
The 14 is about as big as you can go on that gearcase. The 14 1/4 to 15" diameter props are for the V6 style cases.
  #7
Old February 17th, 2009, 05:52 PM
Perhaps if you get a dedicated pontoon prop you could get a little more height.Again on a pontoon probably won't gain much but every little bit helps.
  #8
Old February 17th, 2009, 06:24 PM
Thanks Steele,
After reading other posts, I'm happy that I can turn at WOT and not cavitate!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Damaged 24' Pontoon tmyrick01 Pontoons 10 August 10th, 2008 11:22 PM
Prop on 24' Pontoon Question mpritch272 Prop Questions and Topics 10 May 21st, 2008 08:24 AM
hp for a 24' pontoon patpatrickc Boating, Activities and Destinations 8 January 24th, 2008 01:16 AM
24 foot pontoon trailer lyndze Trailers and Towing 3 August 23rd, 2005 10:50 AM
Starcraft '24 pontoon cocodrieboy Boat Topics and Questions (not engine topics) 1 April 19th, 2004 06:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
