Re: force flywheel
Welcome to iboats.
What hp motor is this?
The best I can do using Mercury's serial numbering method of the early 90's, is to narrow it down to a 1992 or 1993 model. Probably 1993.
Sorry, can't help you on the flywheel from model number to model number.
What motor did the flywheel come off of?
Or, do you have the part number off the original flywheel, and the replacement flywheel?
Part number should be similar to this: 200-859241T09
