  #1
Old February 17th, 2009, 09:44 AM
Chris&Heidi Chris&Heidi is offline
Question Fixing 3" tear on side of Aluminum boat
Any ideas what could be used to fix this?
  #2
Old February 17th, 2009, 09:51 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Fixing 3" tear on side of Aluminum boat
where is it on the boat. i used some duct tape on the inside as backer, and filled one like that with JB Weld Marine, never had a problem with it. it took several applications to build it up.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old February 17th, 2009, 09:59 AM
Quote:
Thanks! It is on the left side right above the rear bench seat.
  #4
Old February 17th, 2009, 10:03 AM
should fix it right up. mine was below the water line.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old February 17th, 2009, 10:07 AM
just put a picture to my previous post what color does the welding stuff turn when dry?
  #6
Old February 17th, 2009, 10:39 AM
gray. you can paint it.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old February 17th, 2009, 02:45 PM
fixmyevinrude fixmyevinrude is offline
You could take it to a weld shop and they could weld it. I don't have a clue to the cost. Take a picture of problem and ask them for a ballpark estimate.
  #8
Old February 17th, 2009, 04:14 PM
Talking Re: Fixing 3" tear on side of Aluminum boat
Thanks for the suggestions!!!!
  #9
Old February 17th, 2009, 05:39 PM
Nandy's Avatar
Nandy Nandy is offline
Tig welding is going to be very costly compared to using jbweld or marinetex. Both should work. I did many repairs with marinetex and jbweld in my johnboats, lots of it under the water line, with no problem...
__________________
1975 Cobia Tradewinds SS-170
Close Bow 17 Footer V-Hull
1975 Evinrude 70573-B 70HP
1968 Babcock
Bow Rider 15 Footer Thrihull
1968 Mercury 500 50 HP
Yes, I could google it, but I rather get advise from my Iboats fellow members...
  #10
Old February 17th, 2009, 06:13 PM
JB's Avatar
JB JB is offline
Just begs for aluminum brazing with a propane torch.
__________________
RED SKY at night. . .
JB
  #11
Old February 17th, 2009, 07:21 PM
kg5388 kg5388 is offline
call the local prop repair guy I had a 4 inch gash and used a hammer and 2x4 to get it back together and he charged $30 to weld it up.
I also had Him weld a Toyota 22-R timing cover when the chain rubbed a hole in it.
  #12
Old February 17th, 2009, 08:41 PM
Nandy's Avatar
Quote:
I got them rods for alum brazing and still have to get temps right and get a good "puddle" going. It is just that detail that darn alum dont glow when it is at the right temp plus I need to practice a bit more. But if the OP can manage it rods are available at homedepot, lowes, harbor freight and others. All you need is a propane torch. It will be money well spent if the OP plan to keep that boat for a few more seasons.
__________________
1968 Babcock
  #13
Old February 17th, 2009, 09:14 PM
bugman1964 bugman1964 is offline
Aluminum melts at a little over 400 deg F. Soot up the aluminum with the flame of a lit candle, or acetylene from torch, turn the aluminum black with carbon. The carbon burns off at a little under 400 deg F. This is a good pre-heat temp for the aluminum when torch welding/brazing. Once pre heated focus the heat on the rod get it melting and braze/weld the repair area.
  #14
Old February 17th, 2009, 11:10 PM
Nandy's Avatar
I thought I heard/read that somewhere but it slipped my mind. My only question is what will that soot do to the brazing quality? I mean, wouldnt that be contaminating the work area? Is an hones question... Im trying that anyway...
__________________
1968 Babcock
  #15
Old February 18th, 2009, 12:26 AM
fishrdan fishrdan is offline
I like TD's JD Weld idea. The dried epoxy is a medium gray color that might not match the aluminum too well, but it you sand the shiny top layer off, it turns a light gray color that will blend much better with the aluminum if you are worried about aesthetics.
The aluminum brazing rods (Durafix) would work nice too, but you should practice a bit with them before attempting a repair like this, if you want it to look good. If you braze that area you should roll the boat over so the area is horizontal as the brazing rod goes from liquid to solid quickly,,, it will run and drip off a vertical surface. Maintaining the right temp is critical since the rod melts about 100* (or something like that?) less than the aluminum base material, you wouldn't want to melt a bigger hole in the boat. All you would need is the brazing rods, MAPP gas torch and stainless steel brush,,, MAPP gas to get that big of an area hot enough, all at once. Google Durafix and watch a few of the videos.
  #16
Old February 18th, 2009, 12:41 AM
slasmith1's Avatar
slasmith1 slasmith1 is offline
It is just a 4" bead of tig any reputable welding shop should be able to do it for less than $100 worst case.
__________________
Thats like wiping your butt before you go. You can do it, but it just don't make any sense.
  #17
Old February 18th, 2009, 07:02 AM
5150abf's Avatar
5150abf 5150abf is offline
the problem with JB is if the repair fails and you decide to weld it you have to try and get all the jb off first, done it, not fun.
You should be able to get that welded for cheap and then it is done.
__________________
GO IRISH!!!!
  #18
Old February 20th, 2009, 01:16 PM
Thanks so much for everyones suggestions. They were very helpful. Have a great day!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fixing my leaky aluminum boat tuneball Boat Restoration and Building 9 February 9th, 2009 11:46 AM
anyone ever heard of "AFP/Aluminum Fabricated Products" or "RDS Aluminum"? weider1717 Boat Topics and Questions (not engine topics) 6 September 7th, 2008 10:40 PM
14 Foot Welded aluminum boat "decking"/flooring re-do. Coednaked Boat Topics and Questions (not engine topics) 0 March 16th, 2008 11:57 PM
fixing little holes thoughout aluminum boat BLLDOGG Boat Topics and Questions (not engine topics) 5 November 30th, 2006 09:40 PM
15" or 20" Transom on 14' Aluminum Boat. Opinions?? nhboater Boat Topics and Questions (not engine topics) 2 August 5th, 2002 07:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
