I have a used boat that has a 1987 1.8 Johnson in it. Right now the motor cranks and starts up perfectly. I am having an issue with the charging system though. I can run the boat for about 1hr, when i turn it off. I switch off my batteries and if i go to start again it wont have enough juice to crank. Where can i start to check for problems?
Second, i had an issue with the trim/tilt system. Somehow the cables that go into the trim motor go pulled out of place and the cables fried. I was able to have the unit repaired, but then i realized that the relay where the motor connects to has melted and fused with some cables.
I already ordered the correct relay, but need to see if anyone would happen to have a wiring diagram. If someone can please help i would really appreciate it. I can post some pictures if necessary. Thanks
