This one starts easily, idles nicely on all three, bring the rpm up untill well past fast idle and it appears to go real real rich and chokes itself. I can get past that point by coming up quickly but it does the same in a few seconds at at say 1500.
Carbs have been cleaned and reset, floats etc. No leaking fuel so the needles are working. Rebuilt the fuel pump. Replaced the plugs with original type. Checked that the coil wires are making good connection. Replaced one coil as it was showing a slightly high primary resistance. Bulb stays firm. No difference if I pump the bulb. Checked the resistances of the stator coils and the gear counter coil. All good. The gapping looks good on the gear counter coil. Wiring is all good. Connectors are all good. Tried swapping the CD unit but no change. The oiling system has been disconnected but had the same problem before disconnect.
Just about had it with this one so any ideas would be very much appreciated.
