Re: Please Help Cant Remove Gearbox Case
There are a few tricks to freeing this up if in fact it is your problem, as Dhadley mentioned, if it did not drop down at all after loosening all bolts, it is likely your problem. If it dropped a 1/4 inch or so, you likely forgot to disconnect the shift rod.
When all is said and done, be sure to grease the splines of the drive shaft with marine grease before reinstallation, and replace the o ring, so that you dont have this problem again!
