Re: trying to lift my 28' pontoon off the trailer
my advice check with a local marina that has the fork lift type deal, and you might even be able to pay to store / rack your boat for a month and pull out from under and get the trailer work done....
unless you can make an overhead beam or something and chain hoist the rear and leave it suspended, its kinda more hassle to pull out the trailer and then get it back on at your home
if you have some way to support the rear, you can slide the front off a few feet at a time and support once off the trailer then just reverse the process when you put the trailer back underneath.
