Re: How do you drill holes in glass?
I did a lot of research on this just out of curiosity, what I did learn was that if the glass is tempered, it takes a specialized glass shop to drill a hole in tempered glass, they do it with a Lazar cutter what ever that is, I also found that many folks have tried with a diamond tip bit only to ruin the glass because it's layered and bonded under extreme heat, it seams some were successful with a water blast machine. So I reckon ya need to call around the glass companies and ask if they are equipped to do the job, I do not know what you are doing but I have used hinges made for glass that have double sided tape and set screws that slid over the edge of the glass
