Barneyfife
- Nov 29, 2008
- 10
OK Experts...need some help: I own a 1982 270 Sundancer with twin Mercruiser 260s. The engines and Gimbal Housings are original...serial numbers of engines and transom plates match original paperwork.
Have owned for approximately 7 years with little trouble. I know when I bought that the sterndrives didn't match, but everything worked fine.
Bought a trailer this year, and brought boat home to do some winter work.
The port sterndrive is a Gen II drive,and the starboard a Gen I. Both the sterndrives and gimbal housings are either pretty beat up or corroded, and replacing everything on the transom is part of my plan.
Here's my question. Everything I'm reading tells me there's not supposed to be compatibility between the Gen I & II drives, but I know there must be a caveat, since my boat's been running fine for all this time with a Gen I gimbal and a Gen II strendrive.
Was there something special done by PO to make this work? What gimbals and sterndrives should I use when I replace these components? It's obviously easier to find nice Gen II gimbals....can I use Gen II gimbals with what's inside the boat? What's the final word on compatibility?
