Re: used motors
I just surfed the net a bit to see if I could come up with a couple of 1232 flat bottom jons in different brands. What I found is that most manufacturers make 1236 boats, rather than 1232.
I did find one being sold by an outfit called DirectBoats.com that is a 1232. It weighs 88 pounds, has a max capacity of 385 pounds, "person capacity" of two, and a max hp rating of 5 hp. My guess is that, if you were to find 1232 jon boats by other manufacturers, you would end up with the same limitations, merely because that's probably what the Coast Guard formula calls for.
So, Wildmanimal wasn't so nuts after all - take his advice and put a small motor on it.
PS: The width value given on a flat bottom jon boat is the floor width, not the width at the rails. That is why this boat seems so narrow to some. That said, its still a very narrow boat.
