  #1
Old February 12th, 2009, 04:32 PM
SCcdp SCcdp is offline
Default Starter solenoid/Starter problem on a 1969 Evinrude 55hp
Helping a friend try to get a boat running and there is a problem with getting it to start at all. After hooking up a fully charged battery and turning the ignition key all we get is a very high pitched hum/whine and no movement on the part of the starter.
Is that hum coming from the solenoid? Any insight on what the issue may be is greatly appreciated.
Thanks,
Matt
  #2
Old February 12th, 2009, 04:36 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Starter solenoid/Starter problem on a 1969 Evinrude 55hp
have you tried turning the spindle on the starter to see if the motor is frozen. sounds like a bad brushes, or armature. new starter is about as much as the motor is worth. take a jumper cable an jump from battery pos post, the the post on the starter. that by passes the solenoid, and ignition switch.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old February 12th, 2009, 04:41 PM
I turned the start spindle up into position with the flywheel but did not mess with it much more than that. I will try to jump it off the way you recommended -didn't even think of that! Thanks!
  #4
steelespike steelespike is offline
Do you get a click?If no click the first place to look is the solenoid and circuit to the solenoid.You could test the starter CAREFULLY by using good jumper cables ground to good ground positive to the post on the starter.Don't make the final connection at the battery.
  #5
Old February 12th, 2009, 04:51 PM
No click whatsoever just a high pitch whine when the key was turned.
  #6
Old February 12th, 2009, 04:53 PM
So ground to a good ground source and attach one positive to the starter post and just touch the other positive to the positive post on the battery?
  #7
Old February 12th, 2009, 07:24 PM
F_R F_R is offline
yes.
Solenoid buzz is a sign of bad connections or cables. You should fix all connections BEFORE making any attempt at starting the motor. If it should happen to start while the connections are still bad, it most likely will destroy the alternator rectifier and maybe the ignition amplifier. Result: Think mega $$$.
  #8
Old February 12th, 2009, 07:58 PM
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971 evinrude 40hp starter/solenoid problem Cgr Johnson & Evinrude Outboards 6 June 6th, 2008 12:01 AM
1968 Evinrude 55hp starter problem jglad Johnson & Evinrude Outboards 4 June 27th, 2007 12:55 AM
Johnson 55hp 1969 no spark when starter spins Freddy49 Johnson & Evinrude Outboards 10 May 17th, 2006 02:38 PM
Slave Solenoid/Solenoid/Starter Problem? rocklydockly Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 25th, 2005 10:02 AM
Starter solenoid problem SS MAYFLOAT Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 June 27th, 2004 07:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
