Re: 1996 150 hp Mercury Cooling Question
Kevin, A lot of those motors only have a telltale when the thermostat opens, and on the flusher in neutral, they do not get too warm, hence almost no telltale. You should actively see the water drawn into the motor upon startup. it will recirculate, and some water is dumped into the exhaust. This will exit thru prop and thru grates above and behind the prop.
Port high up on motor is likely exhaust relief for running in neutral with motor in water. On the muffs, little water will exit here.
