Re: 1993 Mariner 115HP Water in Carb
If the carbs have dirt or rust, you will need to clean them up. Pull one bowl and have a look. If they have dirt or rust, you would need to disassemble, clean all passages with spray carb cleaner and install new gaskets. if the inlet needles don't look OK, you will want to replace them.
