Ive got an 81 Johnson Tiller steer and Im having a problem and am a real novice as far as outboard motors go so Ill explain as best I can and hopefully someone will understand.
When running the motor at around mid range the motor sounds as if it either kicks out of gear or goes into overdrive,when you get on plane it actually rund pretty good but will still do it at top range just not as bad.When it makes the noise and you also feel a lag/the boat drops as if again it feels like its kicked out of gear or went into overdrive or something
I am running the motor on a Seaark 1652 Tunnel hull.
I had a buddy out duckin this morning and we were kicking around the idea of maybe its not drawing enough water,its not peeing hard but its steady,plus there seems to be a second pee hole in the front?
I had the lower unit serviced and the pump changed,but it was doing this before and after the service work?
Also thinking it could be a prop problem I tried pulling off the prop to see if the splines were damaged as it obviously stops or studders (the prop that is) when it makes this sound.But couldnt get the prop off,I pulled out the cotter pin and took off the nut is there something Im missing,I couldnt even pound it off with a rubber mallett
Sorry for the long post but I desperately need some help/ideas!
Thanks in advance.
Chris
Thanks in advance.
Chris
