  #1
Old February 11th, 2009, 09:04 PM
robin99 robin99 is offline
Default Yamaha T9.9erly cold start problem
On my Yamaha T9.9erly cold start problem I can get the motor running by manually choking at the carb throat. But I want it to cold start properly. The carb is clean and the motor is like new. There is a black soleniod on top of the carb the pulls up a needle valve. Looks like is could be a cold start fuel enrichment valve but I don't know. The solenoid has 7.2 ohms across the two black wire leads. How is this device supposed to work? Does is pull in with 12vdc or some other signal? I traced to two black wires and they go up into the magneto? Can anybody send me a wiring diagram or explain what the problem might be?
Thanks,
Robin. Canada, freezing here.
  #2
Old February 12th, 2009, 06:51 PM
rodbolt rodbolt is online now
Default Re: Yamaha T9.9erly cold start problem
that solinoid is indeed an enrichment device.
it works by heating a wax pellet inside.
when cold the needle retracts allowing more fuel through the enrichment circuits to the carb idle circuits.
as the engine runs and the current from the stator lighting coil heats the wax pellet the needle extends closing off the enrichment circuits.
however if the carb is not in top shape or the engine has other running issues it wont work properly.
if the throttle shutter is open when cranking it wont work.
  #3
Old February 12th, 2009, 09:44 PM
n6rfm n6rfm is offline
Robin,
You might also want to take a look at the carb fuel passages again. I had a similar hard starting problem on my T9.9, recently. My mechanic told me he found a bit of crud in what he called a "cross-over" passage, even after I thought I had everything cleaned out. he said it was part of the enrichment circuit.
Good Luck.
Bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 Yamaha T9.94 stroke cooling problem n6rfm Yamaha & Suzuki Outboards 6 August 31st, 2008 12:07 AM
Yamaha T9.9 cooling problem - Help Jadelinski Yamaha & Suzuki Outboards 0 May 12th, 2008 11:36 PM
T9.9 cold blooded Fish mojo Yamaha & Suzuki Outboards 2 December 2nd, 2004 12:01 AM
1995 Yamaha T9.9 Electric start Water Circ gump218 Yamaha & Suzuki Outboards 1 July 19th, 2004 05:19 PM
Yamaha 9.9 won't start when cold Fish lake Erie Yamaha & Suzuki Outboards 2 April 7th, 2002 01:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
