I'm installing a rectifier/regulator on a manual start F40. Is the following correct?
2 identical yellow wires go to the yellow connectors coming from the engine.
red wire goes to battery positive.
black wire gets bolted to engine, along with a black wire I will install from battery negative.
What about the gray wire? If I'm not installing a tach, is it OK to leave it unconnected to anything?
Thanks.
Thanks.
