  #1
Old February 11th, 2009, 07:56 AM
thunderbolt 110 thunderbolt 110 is offline
Default mercury 110 9.8hp thunderbolt fuel problems ??
Hi all
i,ve just got a mercury 110 9.8hp thunderbolt its got a blueband around the lid. i have searched for make/year on web but with no joy. s/number 9034964 any idears???? Now for the running i've changed a faulty ig/coil and getting a great spark on both plugs but engine will only start in gear and on full throttle with the carb pumped full of petrol/gas and cuts out after a few seconds. i have striped and cleaned the carb and eveything seems ok but it must be a fuel problem????? can anybody help.
  #2
Old February 11th, 2009, 09:39 AM
Laddies Laddies is offline
Default Re: mercury 110 9.8hp thunderbolt fuel problems ??
It sounds like you need a fuel pump kit, Use a OEM kit as it contains the check valves and aftermarket don't.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old February 11th, 2009, 10:42 AM
Thanks for reply Laddies
the only known fuel pump system to me is the diaphragm on the carb. i have took this apart and all seams ok ( no rips and filters clean ) is there any other pump system on the engine ??
I am waiting for delivery of mercury manual but all info helps
Cheers....
any idear on manufacturing year ????
  #4
Old February 11th, 2009, 11:15 AM
Well it's newer than I thought so disregard my first answer. I seem to have missed that you gave a serial number. It's a 1973 Belguim built engine. Things that you will need to check on the carb are float lever and making sure that the idle pickup tube is clean, I would suspect the idle tube is plugged.
__________________
  #5
Old February 12th, 2009, 02:13 PM
Hi all
Just about ran out of patience with this motor, Sparks well, plenty fuel in carb and still wont start ive even flooded the carb, pulled it over and over took spark plugs out and they are bone dry ?? doent seam to be pulling fuel through carb, could it have damaged reed valves due to it being stood dry for some time ?????????
  #6
Old February 13th, 2009, 08:08 PM
Cornell Cornell is offline
I have similar problems with my '73 Merc 7.5 HP which should be the same basic motor except carb. But when I prime it by squirting fuel into spark plugs or past carb venturi it will start and run good. Have you tried that? That might help someone figure out your problem. But my motor has good compression which is necessary to suck gas into cylinder to ignite when pull starting. Make sure your choke is closing correctly. I feel that I will have to put new carb gaskets to see if it will help me. I think the fuel pump is connected to the carb and hope those gaskets are included in the kit I bought.
Cornell
  #7
Old February 20th, 2009, 07:28 AM
Angry Re: mercury 110 9.8hp thunderbolt fuel problems ??
Cheers for reply Cornell
i,ll give it a go with the fuel in the chambers and pass the venturi,
but i have replaced all fuel pump gaskets, new spark plugs, good spark on both plugs, new fuel with a 50:1 mix, checked primer bulb and line all OK, There seems to be good compresion on both cylinders.
Engine will start after a lot of messing around and only in gear on full revs, it will run for 10 secs then completly cut off and die....
  #8
Old March 22nd, 2009, 05:37 PM
2Cojones 2Cojones is offline
I'm a newbie w/ this motor, but I do know motors. Laddie is right: if what u say is correct, then your fuel supply is plugged somewhere.
-2C
  #9
Old March 24th, 2009, 10:08 PM
Dennis123 Dennis123 is offline
Hey did you fix that problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 Mercury 9.8hp 110 thunderbolt curveball257 Mercury & Mariner Outboards 2 June 18th, 2008 04:01 PM
Mercury 110 Thunderbolt 9.8hp GregE Mercury & Mariner Outboards 2 July 30th, 2007 10:13 PM
mercury 110(9.8) thunderbolt darcy.h Non-Repair Outboard Discussions 1 August 5th, 2003 02:44 PM
mercury 110(9.8) thunderbolt darcy.h Non-Repair Outboard Discussions 1 August 5th, 2003 02:42 PM
mercury 110(9.8) thunderbolt darcy.h Mercury & Mariner Outboards 1 August 5th, 2003 02:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
