Mine is manual start and just has the charge coil under the flywheel with the 2 ignition coils on the outside. Has points.
What are my options as far as switching to some sort of electronic ignition. I know nothing about it, but I was curious.
How does it work? and do you not have to set timing?
also, is it economical to do the switch? If there is a source I can find information on this, I would appreciate it.
thanks
thanks
