I just bought this motor this summer and only had it out one time on the lake and it gave fit just not wanting to run and it seemed that it was not running on both cylinders. So i checked the spark and the upper coil had no spark, so i installed a new one and still no spark.
The motor will run and idle just fine for about 3.5 min and then die and it wont start again. and as i was messing with it i saw some milky white fluid coming form the frot of the carb. The i drained card and it was just flowing out every time i pumped the fuel bulb.
Any advice would be greatly appreciated..... All the ducks are getting away........
