optimax 200cv not start I?m desperate
dgomis
Hi, I?m from Spain, I have a Mercury optimax 200cv 1999, have 220 hours, the motor was stoped from 8 years.
I change the fuel pumps, the sparks, the cracked sensor.
The motor start and run medium right for 9 months, until enter water in the fuel tank, then:
The motor start and run very bad.
The motor Off and not run more snifff, snifff, i?m crying.
Clean the fuel pump, injectors, sparks, cylinders, checked fuse, etc
The mecanics put the Mercury diagnostic software, in the motor and checked all. Say that all is OK.
Only say error in Lamp.
When try to start the motor with the key the Mecanic say that haven?t light in the Sparks and not start for haven?t fire,
but when conect the computer whith the software, the mecanics say that then has light, but not start.
The mecanics: two diferent, one of the oficial service has no idea that what is the problem, and the other
say that think in the 70% is the ECU, but not is sure. The 2 mecanics checked for separated the motor.
I?m desperated I have the boat Stop from 3 months, and nobody has idea that what is the problem.
ANY IDEA
Very, Very thanks for your help
