I have 2 studs that install to the riser and two bolts for the other 2 holes. I have read on this forum where these should go in easy but I am having to put a good amount of torque to get these seated. The manifold studs go in easy and are finger tight. But these require a nut and wrench.
I took the old studs out of the old riser to compare and they are the same size bolts and the same size manifold threads. They also appear to have not been easy to install and required a bit of force to place originally.
What is the likelihood of cracking this manifold if I continue torquing these studs (they must go down to the un-threaded center area). I am afraid to go further until hearing from you guys. Another option is to back these studs out (half way in) and just use 4 bolts instead of two and do away with studs. The bolts go on pretty easy.
Again, it looks like these studs were also not easily placed in the original manifold either. Is this normal?
