  #1
Old February 7th, 2009, 05:19 PM
iang iang is offline
Cool Yamaha 150 ignition failure
I have a 1991 Yamaha 150 V6 which I have just rebuilt.I have removed the oil pump and wiring and on trying to set up timing and sync I found I have no spark.I do have a manual but there is no wiring diagram showing my ignition system which has a little black box labeled control unit just below the CDI unit.Can anybody tell me if the oil monitoring system has anything to do with some form of shut down of the ignition and if so,how can I get around it?If this is not a problem,then the test procedure,as far as I can make out,everything appears to be OK but the power is somehow going to earth.
  #2
Old February 9th, 2009, 06:46 PM
rodbolt rodbolt is offline
Default Re: Yamaha 150 ignition failure
without a model number can you tell me if this is a US market motor or overseas?
once we figgue out what motor you have we can help.
  #3
Old February 10th, 2009, 03:16 PM
Sorry about that,this is an Aussie motor assembled in Japan,I only know the year approx by the fact that the oil pump is vertically mounted.I have sorted out the spark issue,the ones not firing had oxidised bullet terminals to the coils,a bit of power tune and contact spray did the job.I still want to know if the control unit mountde below the CDI can be disconnected in some way.Thanks.
  #4
Old February 10th, 2009, 06:29 PM
without seeing it I cant say much.
the US V6 motors until 1990 had the oil control module mounted below the engine oil tank and from 1990 the module was internal to the ECU assy.
  #5
Old February 11th, 2009, 05:38 AM
Thanks for your input,greatly appreciated.The module I am looking at appears to be connected to the temp sensor circuit and must be some early form of engine gardian,once I take the boat for a run I will know if there is a problem in this area.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thunderbolt ignition failure skittcat Mercury & Mariner Outboards 1 July 7th, 2008 09:37 AM
04 Yamaha ignition failure bobwinkel Yamaha & Suzuki Outboards 2 March 10th, 2008 05:46 PM
1985 Yamaha 150 ignition problem kerrymc1 Yamaha & Suzuki Outboards 5 October 27th, 2006 05:09 PM
1997 Yamaha 150 jet - powerhead failure biederboat Yamaha & Suzuki Outboards 2 June 12th, 2005 07:27 AM
yamaha vmax 150 powerhead failure davidlrea Yamaha & Suzuki Outboards 3 January 3rd, 2005 11:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
