The motor I am getting I know like I have said has a stripped out gear puller hole. Now in the picture I have seen of this motor it looks like it might have a possible very small chip on the edge of the flywheel. If this is the case, I will just get another since I think this is a very universal flywheel with the 9.9's and 15's.
The problem is that this is a manual start engine and I noticed there are different flywheels for manual start vs electric start.
I know the electric start probably has different gears for the electric starter, but it should also be compatible for manual start as well right?
Question is what years are compatible with the 76 15hp, and can I use the flywheel that is designed for an electric start motor.
