Re: Alunium Brazing Stuff
I have used this product with mixed results.
It is a bit expensive.
I'd say that the repairs are strong, but not as strong as the companys videos portray.
I used it to repair holes in a mercury exhaust water jacket cover and inner baffle with very good results.
I used it to repair the hull on an aluminum boat with good results.
I tried to make a frame for a floor hatch cover out of brand new aluminum channel and the corner joints cracked.
I tried to fix a cracked off blade on the prop of a merc 9.8, with horrific results.
When the prop got hot enough to melt the rod, the prop melted too.
They say you can use a map gas torch and you can if the stock is light enough. If you get into something more like a casting you need oxy acetylene.
They reccomend a "rosebud" tip, and I'd say that works the best. but also say that you can use a cutting tip wide open. I just made a mess trying that. I was not able to get enough control of the heat with a cutting tip.
They provide a special little brush to use, I think that it is stainless. The stuff will not work without the brush and it is easy to burn up the brush, The stainless brush I bought to repplace it did not work as well.
