  #1
Old February 6th, 2009, 02:13 PM
tuneball's Avatar
tuneball tuneball is offline
Default Fixing my leaky aluminum boat
Hello everyone,
I bought an aluminum boat last year which has a leak and I would like to fix it before the season starts. I've already tried filling the boat up with water over the rivet line and marked where it was leaking from, I then drained it and let it dry. I patched all the leaky spots with aluminum epoxy putty. It fixed the leak to a certain degree, not as much as would of like it to. I've heard of some people flipping their boat over and loctiting or sealing all the rivets that see water. My question is does anybody know what product I would use in order to do that. I've checked loctite, but there is like 50 different kinds out there. Please help, anything is much appreciated.
Thanks in advance,
Dan
  #2
Old February 6th, 2009, 02:24 PM
QC's Avatar
QC QC is offline
Default Re: Fixing my leaky aluminum boat
Hey tuneball. The product that you want is called Gluvit . . . I am going to move this over to the Restoration section as you will get more responses there for this type of question . . . Good luck!!
__________________
Havasu Falls, Grand Canyon
  #3
Old February 6th, 2009, 03:17 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
DAN it really depends on what type boat you have, an aluminum jon boat, or a cuddy cabin. we need to know what you are working with.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old February 6th, 2009, 03:27 PM
evinice66's Avatar
evinice66 evinice66 is offline
cabelas aluminum boat patch $6.50 and you need a hand held propane blow torch.... works wonders!
__________________
in order to catch a fish- you gotta think like a fish- in order to think like a fish- you gotta drink like a fish
  #5
sschefer sschefer is offline
The first step in fixing leaks at rivets is to tighten the rivet(S). You can do that with something as simple as a block of steel on the rivet head and then re-peening it with a ball peen hammer. Depending on where it's located it may be a two person job.
Once you have the rivets tightend up, then use GluVit to replace any missing or damaged seam mastic. It will penetrate into the seam and creates a flexible seal around the area.
  #6
Old February 6th, 2009, 05:20 PM
tuneball's Avatar
I have a 14' aluminum, it's a Lund, probably mid 80's.
  #7
Old February 6th, 2009, 09:12 PM
Quote:
It would be prudent to take the time to tighten all the rivets and Gluvit all the seams.
  #8
Old February 7th, 2009, 07:35 AM
5150abf's Avatar
5150abf 5150abf is offline
Concur, rebuck the rivets, all you need is a hammer and something heavy to back it up, another hammer or peice of steel.
Throw the boat up on some saw horses and start filling it with water, put an even spread on the horses as you are dealing with alot of weight, get a couple inches of water in the boat and start marking leaks, rebuck those rivets and you are good.
Have a buddy hold one hammer on the outside of the rivet and you hit the inside of the rivet a coulpe times, problem solved.
Gluvit I'm sure is a fabulous product, only heard good things about here, but brass tacks, it is a band-aid fix, the boat still leaks but the band aid keeps the water out.
__________________
GO IRISH!!!!
  #9
Old February 9th, 2009, 10:49 AM
tuneball's Avatar
Thanks guys,
I will tighten the rivets and Gluvit the seams, should work.
Thanks again,
Dan
  #10
Old February 9th, 2009, 11:46 AM
Tim Frank Tim Frank is offline
If Gluvit is as good as the claims make it sound, would it not make sense to try to work it into all below-water-line seams BEFORE re-bucking the rivets?
That way you are compressing it a bit and that should really give you a better seal.
Last edited by Tim Frank : February 9th, 2009 at 11:47 AM. Reason: spelling and grammar
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Leaky aluminum boat - epoxy weld? Steve Mahler Boat Restoration and Building 7 May 24th, 2007 06:23 AM
fixing little holes thoughout aluminum boat BLLDOGG Boat Topics and Questions (not engine topics) 5 November 30th, 2006 09:40 PM
Leaky aluminum boat Steve Mahler Boat Restoration and Building 3 October 11th, 2006 08:30 AM
leaky rivets on aluminum 10 ft jon boat HUNTERJIM Boat Topics and Questions (not engine topics) 2 November 6th, 2005 02:48 PM
old leaky aluminum boat tiger 650 Boat Topics and Questions (not engine topics) 11 September 28th, 2003 08:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
