  #1
Old February 5th, 2009, 04:50 PM
NewYork's Avatar
NewYork NewYork is offline
Default 2-Stroke 83' Mercury Inline 6
I got this boat and motor last summer and it ran great for about 2 minutes and then it started stalling out. It wouldn't die on me but I was limited to about 10 MPH at WOT. Anyway, I checked the compression today and I was right between 100 & 105 on 1 thru 4 & 6, but #5 was at 90. The boat set for about a year and a half and I changed all of the fluids, but there was about a gallon of gas in the tank and not knowing anything about outboards at the time I put in about 10 gallons of 89 octane gas that contains 10% ethanol on top of the old gas. At this point I feel like an idiot, but I wanted to see what you guys think I should do now and if you think that the motor will be alright.
__________________
If people concentrated on the really important things in life there would be a shortage of fishing poles.
  #2
Old February 5th, 2009, 05:01 PM
Laddies Laddies is offline
Default Re: 2-Stroke 83' Mercury Inline 6
There is a very good chance that the E10 cut the crude loose and now the carbs need to be cleaned and a fuel pump kit installed.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old February 6th, 2009, 09:23 AM
NewYork's Avatar
Well, that definitely makes sense. How should I go about cleaning my fuel system since I ran some really old fuel through it? Is there anything else that you guys think I should do to get the boat ready for spring fishing and do you think that a carb rebuild and new fuel pump will get me running again?
__________________
  #4
Old February 6th, 2009, 11:14 AM
I would drain the fuel tanks and hoses and rinse with fuel. The old fuel if it smells OK and can be strained and ran in a lawnmower, etc. At that point remove the carbs and install a fuel pump kit. It is very important to flush all lines of debrie or they with send more crudes back to the carb and you can start again.
__________________
  #5
Old February 8th, 2009, 12:27 AM
NewYork's Avatar
Thanks for the advise...I will folow your instructions. My first compression check numbers I believe were skewed as I was using a bad battery. I bought a new battery today and re-checked and my compression was as follows: #1 - 105, #2 - 102, #3 - 119, #4 - 101, #5 - 109, #6 - 109. There is some pretty large gaps inbetween these numbers. Do you think that by following your advise that I can regain acceptable compression back? I also found that one of the spark plug wires was badly corroded so I replaced it. The motor will actually start in neutral now where it would not originally. It runs great in neutral and low idle, but once I start to idle up it starts missing a little - but I am running it with muffs on new gas mixed with some seafoam to help clear out some carbon.
__________________
  #6
Old February 8th, 2009, 12:46 AM
It sounds like your making headway you might run some powertune or someother brand of decarbining fluid through it to see if that will even out the compression a little.
__________________
  #7
Old February 8th, 2009, 01:30 AM
NewYork's Avatar
I will try out some Powertune tomorrow...where is the best place to pick that up from.
__________________
  #8
Old February 8th, 2009, 09:11 AM
Powertune is a Mercury product almost any decarbonizer will work to free the rings.
__________________
  #9
Old February 9th, 2009, 04:05 PM
NewYork's Avatar
Perfect...thank you so much for all of your sound advise.
__________________
  #10
Old February 9th, 2009, 04:23 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
You did not indicate how much SeaFoam you added to the fuel. The amount added to the fuel is important. If you only put in the recommended amount needed as a fuel additive (say 1 can per 12-20 gallons) that is not enough to decarb. It is suggested to mix 1 can per gallon of fuel to get effective decarb action. Using a portable tank to do this is a good idea, as you only need a gallon or two of mix to do a decarb. Don't forget to add oil (50:1) to the mix as well if you do not have oil injection. Search this forum for more detailed guidance on decarbing, if you need it.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #11
Old February 9th, 2009, 05:50 PM
NewYork's Avatar
In a portable tank I mixed 1 gallon of gas w/oil with 1 ounce of Seafoam as per the directions and it was smoking quite a bit. So to help in the decarbing process I should put the whole pint of Seafoam in with one gallon of gas/oil mix and run the whole gallon through?
__________________
  #12
Old February 9th, 2009, 11:51 PM
hkeiner's Avatar
Ensign
Yes, one can SeaFoam per one gallon of fuel is the dosage I use for decarbing. Read the below linked FAQ and search this forum for "Seafoam" and "decarb" and you will find a variety of methods suggested, including the use of Deep Creep (spray version of SeaFoam) for spraying into the carb throat with engine running and into the spark plug holes with engine off.
http://forums.iboats.com/showthread.php?t=158076
__________________
  #13
Old February 21st, 2009, 06:42 AM
shanew shanew is offline
Other things to consider, the engine is a six cylinder with three carbs, if one carb is plugged and no fuel/oil mixture is getting to those two cylinders, it will run but it could lead to disaster. It is just good advise to have the carburetors removed and cleaned. And like previously mentioned the complete fuel delivery system needs cleaned. Thats everything from the filler neck to the three circuits in the carburetors. Also, don't forget the lower unit. Change that oil, check for leaks, look for fishing line on the prop shaft. Change the water pump impeller, and if you can afford a water pressure gauge, install one. The boat is new to you, now is the time to make sure everything is working correctly. Remember, there is nothing that will ruin a good day of fishing like having to work on the boat instead of throwing lures. Good Luck!
  #14
Old March 23rd, 2009, 08:42 AM
NewYork's Avatar
So after I rebuilt the carbs and fuel pump and tested the fuel system I moved onto the electrical and ignition side of things. I rewired the entire system, replaced the switchboxes and it still ran horribly. It would idle well, but it would start to bog down and surge around 1500 RPM. So I replaced the plugs, plug wires, and tested the coils as it seemed that I wasn't getting very good spark. I was getting ready to replace the Stator when I decided to try and run her with the rectifier disconnected and to my amazement she ran perfectly. She went from only running at 1500 RPM at about 5 mph to running 40+. The funny thing is that I tested the rectifier on multiple occasions per the manual and forums and the test results showed the rectifier as good. But anyway she is running perfect now and I am soooooo Happy...thanks for all of your help - there is no way I could have broken down the process of elimination without the help of this forum.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
115Hp '83 Inline 6 stalls trying to accelerate under load ericstiffler Mercury & Mariner Outboards 1 August 8th, 2008 09:31 PM
'83 Evinrude 15hp 2-stroke smoking and dying woodowl Johnson & Evinrude Outboards 2 May 15th, 2008 06:18 PM
Plug Gap ?? '83 Johnson 60HP, 2-cyl, 2-stroke. Kymasabe Johnson & Evinrude Outboards 2 February 8th, 2008 07:31 PM
Best 2-stroke oil for my '83 Johnson 60 Kymasabe Johnson & Evinrude Outboards 9 February 7th, 2008 08:40 AM
Will '74 carbs fit on a '83+ inline 6? ZmOz Mercury & Mariner Outboards 6 August 4th, 2004 07:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
