  #1
Old February 5th, 2009, 02:53 PM
dpepper dpepper is offline
Default Painting my aluminum boat
I am looking into painting my aluminum boat. However, there was a question I have about some stuff on the bottom. Its a gamefisher boat, and it has this hard (almost like bedliner) black stuff on the bottom, and its rough. Could I sand that smooth to paint it? Or is there a reason why it is rough like that? It seems like without that, there would be less resistance. I am new to all this, so sorry if I look dumb..
  #2
Old February 5th, 2009, 03:49 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Default Re: Painting my aluminum boat
Ayuh,... It proably Is bedliner...
I don't know how to deal with Recoating old bedliner,+ haven't seen any conversations about it,...
Go down to the Restoration forums,+ Try asking down there...
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #3
Old February 6th, 2009, 07:01 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
well those smooth bottoms get slick, what are you going to use to paint the boat. i would try a patch and see how it sticks.
did a some looking, looks like all the bedliners are polyurethane based, an acrylic paint should bond with it not problems. if clean. imho.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old February 6th, 2009, 07:11 AM
5150abf's Avatar
5150abf 5150abf is offline
Probably is bed liner, I would suspect that the boat leaked and that was thier fix.
Never done it but I imagine getting bed liner off would not be fun job, if you could even do it, if it will sand by all means do it, if not i would be tempted to paint over it, I am told a rough bottom is actually faster than a smooth one, something to do with breaking the water tension.
The problem with painting aluminum is getting the paint to stick, if you have a good base coat use it.
Anywhere on the boat you intend to paint that is bare metal should be scuffed,(320 sand paper or Scotch Brite pad) and then hit with a light coat of etching primer, after that you can use any kind of paint you would like.
Anything that is painted only needs to be scuffed, no need to take all the paint off.
__________________
GO IRISH!!!!
  #5
Old February 6th, 2009, 10:58 AM
KLINDWW KLINDWW is offline
If it was my boat I would get it off. I don’t think it is making the boat any faster that is for sure. You might go by a shop that does bed liners and ask about the best way to remove it, but I don’t think normal sanding is going to do much. I would think that you would have to more like scrap it off. How ever it is done it will not be much fun unless the bed liner boys have some secret. As far as painting, once the area is sanded to you satisfaction, whip the entire area down with a 50/50 solution of water and distilled vinegar. The vinegar is a good cleaner and also etches the bare aluminum. Once the area is good and dry, you will need to prime any bare aluminum with zinc chromate primer. Once it is primed with the zinc chromate, you can continue with regular primer for what ever type of paint that you are going to use. As far as what type of paint, that is a personal preference driven by what the boat is going to be used for, and how much you want to spend. By the way, once I got the liner off I would put some water in the boat and check for leaks before I started doing any prep work for the painting. If you find a good way to get liner off, please make sure you post it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum boat painting TexasMaidTahiti Boat Restoration and Building 2 August 25th, 2008 06:16 PM
painting aluminum boat? cpr1717 Boat Restoration and Building 3 February 27th, 2008 10:17 PM
painting my aluminum boat jscotty Boat Topics and Questions (not engine topics) 2 July 21st, 2004 08:22 AM
Painting Aluminum boat mattconlon Boat Topics and Questions (not engine topics) 7 June 22nd, 2004 01:10 PM
Painting an Aluminum boat JTMaclain Boat Topics and Questions (not engine topics) 3 September 29th, 2003 07:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
