jamierice426
- Nov 16, 2008
- 1
Hopegully someone might have an idea of what is going on. I recently bought a 1973 Evinrude 135 starflite. I went through the motor pretty well before taking it out on the lake. Plugs, impeller, new gas, compression check, cleaned carbs, decarbed at ramp before taking out. It revs p and idles ok when warm. I still have to use starting fluid to get it to start though. What is a common problem that would cause this? I was thinking possibly the fuel pump but wasn't sure. I wqas really ready to take it out and see how it ran so even though it was hard to keep it running I went ahead and took it out and got the boat on plane. Got about 500 yards at wot and the ungine shut off. It would not turn over and I could not move the flywheel by hand. After letting it sit for about 10 minutes I was able to start it back up and head back in. About half way in it did it again but only a couple minutes and it started back up. Also, when I checked compression all were at 150 accept for one which was at 90. I haven't checked it since I started it the first time. I was hoping the rings would seat and it would pick up but not sure yet. Any suggestions of what to check would be appreciated.
