I have a 1997 40 Hp Johnson (J40TLEUC) that needs a new pinion and forward gear. My question is this: If the new pinion is the same thickness as the old, do I need to do the driveshaft setup with the special shimming tool? My guess would be that I do not have to. Also, is there an easy way to remove the two driveshaft bearings pressed into the gearcase forward of the forward gear without using any special tools?
Thanks in advance for the help.
Be Well
Rob
Be Well
Rob
