  #1
Old February 2nd, 2009, 02:21 AM
fnlyfree's Avatar
fnlyfree fnlyfree is offline
Default 1998 Yamaha ignition/idle problem
I have a 1998 Yamaha 200 V Max. Recently it has started idling at a higher RPM (sometimes) and I started hearing a weird sound pinging from the engine. This only happens while the boat is in neutral. I found that the sound I was hearing was the starter trying to engage as if it were being cranked while the engine is running. I can move the ignition key around a little and cause the idle rpm to drop some, but this also cause the throttle respons to be very poor. My first thought is that the ignition switch is the problem but I am not sure. The engine will turn over and start up fine. The problem happens during idle in neutral. Can anyone offer any advice on this and maybe a part number for the ignition switch only. I believe the control box is a 704 yamaha model.
  #2
Old February 4th, 2009, 11:07 AM
rodbolt rodbolt is offline
Default Re: 1998 Yamaha ignition/idle problem
sounds like you may have a switch problem.
with the engine running unplug the starter relay at the relay and check for 12 volts while its acting up.
if you find 12 volts with the key in the run position something is wrong.
not only will 12V at the relay cause the starter to try to run it will signal the ECU to advance timing and go to cranking mode.
  #3
Old February 4th, 2009, 08:31 PM
fnlyfree's Avatar
I appreciate your help. I will take your advice and check the voltage at the relay. Would you have any ideas on where I could find a replacement switch if necessary? I believe that there should be some aftermarket switches available, but I'm having some trouble finding them.
  #4
Old February 4th, 2009, 08:41 PM
depends on the panal and is the original switch a yamaha one.
any yamaha dealer can ID the switch if its bad and supply a replacement.
most aftermarket switches I have seen are mostly junk.
we see a lot of bass boats with the finest Yamaha engines on the market rigged with the cheapest aftermarket junk avalible, go figgure.
  #5
Old February 28th, 2009, 10:45 PM
fnlyfree's Avatar
I am having trouble finding a key switch for my boat. I have a series 703 yamaha control box. I went to one of my local yamaha service shops and the parts guy said that he was having trouble locating it. He did not seem very interested in helping me though. Can anyone offer any help with this?
  #6
Old March 3rd, 2009, 03:53 PM
natecollins1 natecollins1 is offline
Hi,
If you have a Yamaha 703 side mount control box the main key switch assembly is located here:
http://www.georgiawatersports.com/pr...2&idcategory=0
  #7
Old March 6th, 2009, 05:21 AM
fnlyfree's Avatar
Quote:
Originally Posted by natecollins1 View Post
Hi,
Thanks for the help. I have still not located a switch so this is great. The service guy that I talked with locally did call back and say he thinks he can get me one for around $150. Oh well, I will try the link you gave me.
  #8
Old March 6th, 2009, 11:00 AM
cousinabe's Avatar
cousinabe cousinabe is offline
I use www.boats.net for my parts.
Here is a diagram of the 703-82510-42-00 key switch.
http://www.boats.net/parts/search/Ya...201/parts.html
see part #44
http://www.boats.net/parts/detail/ya...510-42-00.html
  #9
Old March 6th, 2009, 10:52 PM
fnlyfree's Avatar
see part #44
Thank you. Is this part different from the one in the previouse post? Part number 703-82510-43-00.
  #10
Old March 7th, 2009, 11:10 AM
cousinabe's Avatar
here is the latest version of the part http://www.boats.net/parts/detail/ya...510-43-00.html
however, nate's post above had it a little cheaper.
  #11
Old March 8th, 2009, 06:21 AM
fnlyfree's Avatar
Thanks for your help.
  #12
Old April 18th, 2009, 09:33 PM
fnlyfree's Avatar
I meant to post this sooner. I picked up a new switch, installed it and the problem is fixed. Thanks for everyone's help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 Yamaha 9.9 4 stroke idle problem timberwood Yamaha & Suzuki Outboards 1 August 19th, 2008 07:32 PM
1998 yamaha s225txrw ignition problem T Dickson Yamaha & Suzuki Outboards 6 August 9th, 2008 09:13 PM
1998 115 Johnson Idle Problem george3819 Johnson & Evinrude Outboards 1 July 12th, 2006 02:48 PM
1998 40hp idle problem NMMS Johnson & Evinrude Outboards 0 July 13th, 2005 05:47 AM
Intermitent ignition Problem Merc 1998 75hp 2stroke stanois Mercury & Mariner Outboards 3 July 15th, 2003 09:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
